- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
My Extenders Say Password is Wrong
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have 2 WN300 extenders and neither will let someone else login to them. They work fine with my laptop but not with my wifes ipad, and it's very annoying when we have guests. They both say the password is wrong. I have used the numbers printed on the extenders, both the pin and the MAC. I have gone to mywifiext.com to try to change the password, but it tells me the original password is wrong. I have tried resetting both of them. Any ideas?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: My Extenders Say Password is Wrong
Hello obidos
have you tried to change the security type of the password to wpa2?
DarrenM
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi Darren--
How does one do that? I'm using the WPS pin as a password. I don't see anything about WPA.
- Mark as New
- Bookmark
- Subscribe
- Permalink
obidos
Ok if you are using WPS then it should be the one listed on the Advanced wireless settings page. If not have you tried to use your main routers password to connect?
DarrenM
- Mark as New
- Bookmark
- Subscribe
- Permalink
Dannen--
That did it!! I used the password for the router and now the extenders work. Obviously, I never thought, or would have thought of that. Thank you very much for your help.
M
