× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
My pc won't connect to the extender (EX3110 Ac750
SWLY123
Follower
We bought this extender and I set it up. It worked just fine for a while, but then it just stopped. I restarted it and it worked for like a minute and then did the same thing again. I tried resetting and a few other things, but I don't even know what to do at this point, It seems like my phone can connect to it, only sometimes and not all the time though. Any help would be useful, if not than I will probably get a different model.
Message 1 of 2
Christian_R
NETGEAR Employee Retired
Re: My pc won't connect to the extender (EX3110 Ac750
Hello SWLY123,
I would suggest to factory reset the extender and run through the setup assistant again. Have you tried moving the extender closer to see if there are any improvements?
Also, please note that if you recently purchased your device, your extender is provided with 90 days of complimentary support with our support team which can be accessed by registering your device using the link below.
https://www.netgear.com/support/default.aspx
Christian
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 464 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
