× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
Mynetworkname_2Gext/5Gext problems
AuBarr
Follower
Model EX7300 step 8 bolth the new extenders come up in phone with letters and number instead of wifi name. Normal Wifi password does not work. I believe I did everything right so far
Message 1 of 2
DarrenM
Sr. NETGEAR Moderator
Re: Mynetworkname_2Gext/5Gext problems
Hello Aubarr
If you connect to the extender via ethernet port and log in via www.mywifiext.net login with admin/password then go to the wifi settings and you should be able to change the SSID and the password. If this is still not working I would suggest factory resetting the extender and try the setup agian.
DarrenM
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 5359 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
