dohmai's avatar
dohmai
Follower
Jul 18, 2019
N300 EX2700 Wifi Extender Green Lights but No Internet
I have been using the N300 EX2700 Wifi Extender with a Linksys E1200 with no major issues for a couple of years, but now I'm having a problem I've never encoutnered and can't seem to find any support online for:
Details of Problem:
I had a power outage while I was out on a short trip, so it's possible my internet has been problematic since then. Upon returning, the EX2700 still extends the network and the the _EXT SSID is still available, and all the front LEDs are green...
But when I try to join the network with any device (phone, laptop, iPad, PS4), the device connects, but shows "No Internet Connection" and does not have internet connection.
Things I've Tried (that didn't work):
- I rebooted the modem and router and extender
- I factory reset the extender and went through the setup process all over again
- I updated the extender firmware (since the extender stopped working before the firmware update, I don't think this is the cause of the problem)
One Thing that "kind of" worked:
- After factory reset of the extender, I set it up in the same room as the router. After setting up, I was able to connect to the _EXT network AND able to access the internet (at a slightly lower speed than the router's network).
- HOWEVER, once I moved the extender back to where I've had it for years, it stopped working and gives me the No Internet Connection error, despite having green lights all across.
The place where I had the extender does have pretty poor signal of the router network, so I would normally have just assumed it was out of the router's range... BUT:
- all the lights are green
- I had the extender in the exact same location for year without problem
So I'm confused.. any ideas?
Thanks!!
1 Reply
  • plemans's avatar
    couple things could have happened.
    Are you in an area with a lot of wifi interference? Aka a lot of signals? When your power rebooted everything, maybe the router switched to a different wifi channel or a neighbors switched to a channel thats causing interference.This could have caused enough interference so you aren't able to reach as far. 2.4ghz is sensitive to interference.
    Try downloading a free wifi scanner for your phone or pc and see which channels have the least interference. Shoot for channels 1-6-11.
    And then test. See move the extender around, speedtesting while you're doing so to evaluate placement and interference. Hvac, concrete, brick, and foil lined insulation do a great job of blocking 2.4ghz so moving a couple feet can make a big difference. This is why I recommend speedtesting with placing any extenders.
    I would start with these steps and see how it works.
