Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
N300 Resetting Requirement For a Different Network
- Mark as New
- Bookmark
- Subscribe
- Permalink
2017-11-13
10:08 AM
2017-11-13
10:08 AM
What is required to set up a N300 model WN3000RP extender in a different location from the original setup location, using the genie Smart Setup procedures? The NETGEAR_EXT does not come up when viewing available networks on my iPa which, is step one. Does the procedure require the device to be 'reset' before a new location can be set up?
Model: WN3000RPv2|N300 WIFI Range Extender
Message 1 of 2
Labels:
- Mark as New
- Bookmark
- Subscribe
- Permalink
2017-11-15
03:44 PM
2017-11-15
03:44 PM
Re: N300 Resetting Requirement For a Different Network
If you are connecting the extneder to a new router then yes you would need to factory reset the unit if you are just moving it and staying connected to the same router than no you would not need to.
DarrenM
Message 2 of 2
Announcements
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
