× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
N300 WiFi Range Extender
lazerponygt
Follower
I am trying to increase the signal of my Arlo security cameras.  As 2 out of 4 are outside, they have a weak signal and often go offline.  I have the extender connected to my wifi network, and have connected the Arlo base unit directly to the extende via ethernet cable, but the signal to the cameras has not changed.  Can the extender signals pass through the brick of my house?  The front door camera is only 12 feet away from the base unit, but only has two out of three bars.  If I place the camera directly inside the house, all bars light up.  As soon as it passes through the front door, the bars drop down.  Is there anything I can do?
Model: EX2700|N300 WiFi Range Extender
Message 1 of 2
DarrenM
Sr. NETGEAR Moderator
Re: N300 WiFi Range Extender
Seems like the brick is just limiting the wifi signal you may just have to re position things to find the best signal.
DarrenM
Message 2 of 2
Discussion stats
  • 1 reply
  • 406 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
