- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
N300 WiFi Range extender-no internet secured
- Mark as New
- Bookmark
- Subscribe
- Permalink
All the lights on my extender are green. When i try to connect using the .EXE connection, I receive a 'No internet, Secured' message. I can connect using the regular connection (the one without the .EXE on the end)
I had this issue last week, I reset the device to the factory settings and redid the set up process. This did work. I am once again not being able to connect to the .EXE. I have reset the device again, however, this time, I am still receiving the 'No internet, Secured' message when I try to connect.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: N300 WiFi Range extender-no internet secured
I'm having the same issue, My Router Link is Green, Client Link is Green & Power & WPS is green. and my computer down the bottom says internet access but then when i go to search something in google "Your computer is offline", I've restarted my computer 3 times, Factory reset the N300 2 times & have set it up 2 times. I've been trying to fix this for 5 hours now.. So you're not the only one having issues with these crappy products. Never buying NETGEAR products again.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello Lonnifer
Since doing the factory reset have you tried to tell the PC connecting to the extender to forget the network they try to connect to it again?
DarrenM
