jameswatts
Mar 08, 2020Initiate
N300 keeps asking for username and password
Hello
I successfully connected my N300 WiFi Range Extender (EX2700) to my Plusnet router 9 months ago. I have now got a new internet provider and router - Virgin Media - and want to connect my N300 to the new network.
Everytime I press 'log in' on NETGEAR_EXT, it keeps asking me for my username and password even though it's correct. I've factory reset the N300 and it's one foot away from the router.
I've tried to log in with admin and password instead of my email address, but that doesn't work.
Any ideas gratefully received - thank you!
James
try a different pc/browswer. many with the password autofill will overwrite what you're putting in.
Also, when some do a factory reset, the just hit the button. you need to push and hold while powered on for usually 7-15 seconds. The lights should change when its held long enough.
you can also hardwire into the extender for setup. this usually goes faster/smoother than connecting over wifi for setup.
- jameswattsInitiate
thank you - i used an ethernet cable and it worked!
