- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
NETGEAR AC2200 WiFi Extender (Model Number: EX7300) - Extender's WiFi is not working
- Mark as New
- Bookmark
- Subscribe
- Permalink
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi @Chase44,
Thank you for the update. Please try updating the firmware of the extender to the latest version (1.0.2.136) and do a factory reset. You can do it manually by downloading the firmware from here. After that, try setting up the extender again. Please keep us posted.
Dexter
Community Team
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: NETGEAR AC2200 WiFi Extender (Model Number: EX7300) - Extender's WiFi is not working
If you used WPS during the extender setup, you could try another reset, and this time don't use WPS. Instead, join the extender network and browse to www.mywifiext.net to complete the setup. Disconnect the ethernet cable before you try this.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have reset the extender without using WPS and the WiFi is still not working. Also, I can't browse to www.mywifiext.net because the WiFi from the extender does not work unless I use the ethernet cable.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi @Chase44,
1. Accessing the extender's UI via www.mywifiext.net does not require Internet access. 2. Does the extender show up as an attached device when looking at your router's UI?
3. What is the firmware version of the extender?
Dexter
Community Team
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I was able to get on to www.mywifiext.net and I went through all of the steps as if I was setting up the extender for the first time. I was able to complete the setup process with no issues but after doing so 3 separate times the extender's WiFi still wasn't working. The extender does show up as an attached device when I'm looking at my router's UI. My extender's firmware version is V1.0.1.78
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi @Chase44,
Dexter
Community Team
- Mark as New
- Bookmark
- Subscribe
- Permalink
