× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
NETGEAR EX7000 Connection Problems
Rufi34
Hello Guys,
i have a big issue with my Range Extender* ( EX7000). (I'm connected to the 2GEXT.)
The problem is that my Labtop, Computer connects fine to the RE* ... but my other devices like my PS4, Iphone , IPad have Problems with the Connection.
I solved the Problem on the I/phone/pad by typing the CLIENT-ID manually in the WLAN Settings from the RE.
But on the PS4 i can't connect to the RE. I tested it via LAN and WLAN Connection.. FAILED.. But when i connect to the main WIFI Connection everything works fine..
Also tried to reset the RE Device.. same result. I also have Problems to connect on http://mywifiext.net/. My Internet explorer tells me ERR_CONNECTION_TIMED_OUT while i'm connected to the RE Device...
Can anybody help me or have the same Problem with the RE EX7000 ?
Thanks
Rufii
Message 1 of 4
DarrenM
Sr. NETGEAR Moderator
Re: NETGEAR EX7000 Connection Problems
Hello rufi34
Have you tried to reserve the IP of the extender and the PS4?
DarrenM
Message 2 of 4
Rufi34
Hello DarrenM,
thanks for your reply 🙂
Sorry how can i do that ? Do i have to do this in my Main Router settings or on the Range extender ?
Greetings
Rufi
Message 3 of 4
DarrenM
Hello Rufi34
That would be on the main router.
DarrenM
Message 4 of 4
Discussion stats
  • 3 replies
  • 3707 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
