Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
NETGEAR Ex6120 - constant switching networks?
- Mark as New
- Bookmark
- Subscribe
- Permalink
2018-12-22
03:50 AM
2018-12-22
03:50 AM
Hi,
Just bought and definite improvement in signal quality when I connect devices to the “_5GEXT” extended network in other rooms in the house.
Possible stupid question - if I’m the room that my actual router is placed (and has the strongest signal in the house) is it the case I have to reconnect my device from the EXT network to the original network every time I move to that room? In other words its a case of having to constantly switching between
both main and EXT networks if I’m moving between ‘router’ room and other rooms?
Cheers
Cheers
Model: EX6120|AC1200 Dual Band WiFi Range Extender
Message 1 of 2
Labels:
- Mark as New
- Bookmark
- Subscribe
- Permalink
2018-12-22
04:40 AM
2018-12-22
04:40 AM
Re: NETGEAR Ex6120 - constant switching networks?
@Hibsred wrote:
its a case of having to constantly switching between both main and EXT networks if I’m moving between ‘router’ room and other rooms?
Yes.
But you can try changing the EXT network names to match your router. Then your devices often will choose to roam between the networks. However, you still might need to toggle wifi off/on on the device when you change "zones" - that depends on how aggressively the clients roam.
Message 2 of 2
Announcements
