Reply
Need help with two routers
Jitin100
Follower
I have a cax30 and an mk63. Can’t get access to the mk63 router. Tried 192.168.1.1, that goes to cax30. Tried 192.168.1.2, goes nowhere. The nighthawk app doesn’t enable any advanced features. What to do? How to get access to the mk63??
Message 1 of 2
Guru
Re: Need help with two routers
Is the MK system in access point mode?
Otherwise you're in a double nat
https://kb.netgear.com/30186/What-is-Double-NAT
if you're wanting to use both systems, put the MK system in access point mode.
Disconnect it from the CAX and reboot the mk system. Then connect a device to the mk system (without it connected to the cax) and go to routerlogin . net  or its ip address. then put it in access point mode and reconnect it to the CAX.
It'll reboot. Then you should be able to log into the CAX's attached devices page and find the MK systems IP address.
Current Setup: CM2000-> RBK750-> GS716v2-> RAXE500-> Pi-hole->
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 72 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
