- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Need recommendation...BEST WIFI EXTENDER for use with NightHawk R7000 using the 5Ghz
- Mark as New
- Bookmark
- Subscribe
- Permalink
I am in need of recommendation for a WIF Extender for my NETGEAR Nighthawk Smart WiFi Router (R7000). In particular.... I am in need of something that takes advantange of the wireless 5Ghz connection I currently use from my home fiber internet.
It is for home office desktop use.... needing the best reliable connection for video editing without breaking the bank $$$.
Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Need recommendation...BEST WIFI EXTENDER for use with NightHawk R7000 using the 5Ghz
@d7D777 wrote:I am in need of recommendation for a WIF Extender for my NETGEAR Nighthawk Smart WiFi Router (R7000). In particular.... I am in need of something that takes advantange of the wireless 5Ghz connection I currently use from my home fiber internet.
Thanks
that's your key right there. You can go to the netgear extenders section
https://www.netgear.com/home/products/networking/wifi-range-extenders/
and narrow it based on technology you want. like 5ghz wireless ac1900. it'll narrow it to the devices that support that spec. Then you can pick from there. You asked about the best and I could say the EX8000 but if its outside of your budget, it doesn't do much good.
