Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Need suggestion for WIFI range extender for my R7000 router
- Mark as New
- Bookmark
- Subscribe
- Permalink
2020-12-18
01:50 AM
2020-12-18
01:50 AM
Hi,
I am using Netgear R7000 router and I need suggestion regarding WIFI range extender for the same,
it will be helpful if you can suggest to me which WIFI range extender to go for that supports R7000.
Thanks
Model: R7000|AC1900 Smart WIFI Router
Message 1 of 2
- Mark as New
- Bookmark
- Subscribe
- Permalink
2020-12-18
12:57 PM
2020-12-18
12:57 PM
Re: Need suggestion for WIFI range extender for my R7000 router
All of netgears would work.
It depends on what range you're trying to achieve, performance goal (single band<dual band<triband), and even budget. Its pointless for us to recommend a $200 AX extender if you're budget is $40.
I will say, i usually recommend the triband versions because they don't take the 50% speed hits the single/dual band extender take.
https://www.netgear.com/home/wifi/range-extenders/
Message 2 of 2
Announcements
