rosalie
Jan 08, 2020Follower
Net Gear wifi range extender
I installed netgear wifi range extender Model WN3000RP late last night. I can't remember name and password when I tried setting up wifi connection on my iphone. I've tried entering my security answers and they don't match the user name. I also don't know what password it's asking for. Tried my SSID password but this has no user name. How can I start from scratch? Is this possible?
1 Reply
If you didn't setup the password recovery option and didn't disable them, it still asks the questions even though there isn't a correct answer.
If you don't konw the login info and didn't setup a recovery option, your easiest choice is a factory reset and reinstall.
To reset, push and hold the reset while the device is fully powered on. It should take roughly 7-15 seconds. The lights will change/blink when its held long enough.
that'll get you back to the default info.
default login is: admin
default password is: password
they are case sensitive.
