× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
NetGear CGD24G8D
MeeX
NetGear CGD24G8D
when i restart netgear CGD24G8D my network is encrypted with wpa2... is that normal? i cant access the router... 😕
Message 1 of 4
jmizoguchi
Virtuoso
Re: NetGear CGD24G8D
either someone has setup with default encryption key..
these units is ISP provided (branded firmware) unit so they may have default encryption that they provide to customer or you just need to login the unit and change it.
even login user/pass and is not same as netgear default so suggest contact ISP support
Message 2 of 4
MeeX
hmmm... well on the back of the AP says one MAC and in inSSIDer says totaly different...
MAC on back 0026F227558E
MAC in inSSIDer 0026F2235BC2
and default password field is not filled...and yet it says WPA2 .. i had to restart it because i forgot my old pw.. 😕
Message 3 of 4
jmizoguchi
Virtuoso
likely those are WAN side of mac address so it will show different ..
mac address is not encryption anyway so you are even remotely close to WPA2 anyway
default password does not sounds like WPA2 related.. default password are related to router interface
CALL YOUR ISP and ask for help
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 2722 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
