× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
NetGear WiFi Range Extender- not connecting to new router
jac_pace
We bought a new router and now we cannot get the range extender to connect to it. It worked fine with out other one. The old one was a netgear router, but the new one is asus, does that matter?
My husband tried to set it up using the WPS, but it is asking for a PIN number, which we don't know where to find. Can anyone help?
Model: WN2500RPv2|N600 WiFi Range Extender
Message 1 of 5
DexterJB
NETGEAR Moderator
Re: NetGear WiFi Range Extender- not connecting to new router
Hi @jac_pace,
Welcome to the community!
1. You can try resetting the extender back to factory settings then go through the setup procedure. The links below may help out.
Reset: Page 39 of the user manual on this link.
Installation guide: Here.
Dexter
Community Team
Message 2 of 5
jac_pace
Hello. Do you know where to find the PIN number? It has been reset to factory settings and then hit the WPS button and it is asking for a PIN.
Message 3 of 5
DexterJB
NETGEAR Moderator
Hi @jac_pace,
The PIN is usually generated by the router. You may contact the router manufacturer for support regarding the PIN.
Dexter
Community Team
Message 4 of 5
DexterJB
NETGEAR Moderator
Hi @jac_pace,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team
Message 5 of 5
Discussion stats
  • 4 replies
  • 1055 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
