× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
NetGear WiFi Range Extender
josukie
I recently required netgear tech support  regarding fixing and resetting a new wifi password.  I was transferred to India and was helped but during support call I was told my fire wall was not working and they could clean and put a new firewall in when my receipt came to my email address it was to a co called SmartFares and cannot speak to anyone at netgear verifying this is a valid netgear affiliate.  I previously paid a 3rd party company for a product support and I believe they created the problem I needed to contact netgear about.  How can I reach someone at netgear to verify this?
Model: EX2700|N300 WiFi Range Extender
Message 1 of 7
Guru
Re: NetGear WiFi Range Extender
I don't think you reached Netgear support, it looks like you contacted someone else.  Did you use my.netgear.com?
Hopefully a Netgear mod (perhaps @DexterJB ) will follow up.
Message 2 of 7
schumaku
Guru
@josukie wrote:
... I was transferred to India and was helped but during support call I was told my fire wall was not working and they could clean and put a new firewall in when my receipt came to my email address ...
Reads like a typical support Scam - your computer firewall config was changed, some backdoors were installed, and it's just a question of time until your computer will be abused for criminal purposes. Stronlgy suggest to start to check and clean your computer(s) for malware et all ASAP.
Message 3 of 7
josukie
but i contacted support thru netgear.com, how are you suppose to know if it is REALLY netgear?
Message 4 of 7
josukie
I contacted netgear support, how would it go to scam unless someone thru netgear transfers to scam and how do i speak to someone at netgear?
Message 5 of 7
Guru
You didn't say that in your first post.  Did you use the gearhead support, or something else?
Message 6 of 7
josukie
you have phone options, I chose technical support.  The 1st level was unable to correct problem and told me I was being transferred to higher level of support.  I have since tried to reach someone to verify if they were valid 3rd party, no one knows but they did create a ticket, but so far no one has responded.  I also reviewed thru Amazon regarding my issue and so far no response from there
Model: EX3700|N600 WiFi Range Extender
Message 7 of 7
Discussion stats
  • 6 replies
  • 1303 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi 770 Series
