- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Netgear AC1200 (EX6110) Unable to connect to Extender after Extender is connected to WIFI Network
- Mark as New
- Bookmark
- Subscribe
- Permalink
WIFI Range Extender has connected to the WiFi Network. I can see the names of the new available networks.
HOWEVER, once i have found the network, I CANNOT connect to either of the new extender WIFI networks. There are two new names xx_2GEXT and xx_5GEXT on the list. The quick install quide says to use the same WIFI password that you use for your WIFI Router.
It is NOT working.
Help
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Netgear AC1200 (EX6110) Unable to connect to Extender after Extender is connected to WIFI Networ
Did you install it with wps? It doesn't always work as different manufacturers code differently.
Try factory resetting the extender and then reinstalling using the installation wizard
- Mark as New
- Bookmark
- Subscribe
- Permalink
In my quickstart guide the words used are "installation assistant" Is this the same as your reference "wizard"?
- Mark as New
- Bookmark
- Subscribe
- Permalink
