× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Netgear AC1200 WiFi Range Extender
Winbag
Follower
HI
I have 2 of these extenders, worked great until I had to change out my modem and get a new password.
I followed online instructions (or so I thought) to get these wirelessly connected.
However, I am doing something wrong.
These are too new to be damaged.
Anyone have simple easy step by step instructions?
I can follow...but I must have missed something on the online tutorial
Original set up was easy peasy...now new modem with a new password is screwing up so much.  Help if you can.  Thanks much
Model: EX6150v2|AC1200 WiFi Range Extender
Message 1 of 2
Guru
Re: Netgear AC1200 WiFi Range Extender
Anytime you swap out modems/routers its best to reset the extender back to factory and redo the installation from stock.
Did you do this?
If not, hold the reset button for 7-10 seconds (while powered on) until the lights change. Let it go through the reset and bootup and then try redoing the install using the instructions.
https://www.netgear.com/support/product/EX6150v2.aspx
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 457 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
