wdb2005
Apr 26, 2020Follower
Netgear EX2700 Wifi Range Extender keeps disconnecting
My WiFi range extender keeps disconnecting. I have the latest firmware update and I've done a factory reset multiple of times and even a hard reset as well as having an ethernet cable connected to my computer yet the problem still continues to persist. Is there any way to fix this?
1 Reply
What router are you using?
the router is the backbone of the system and what the extender is running off.
Have you setup a static ip address in the router for the extender?
