Fr0sty
Sep 16, 2017Follower
Netgear EX7000 series questions
Hi all,
I was trying to find out what the differences are between 3 different models of the ex7000 are:
EX7000-1AZNAS
EX7000-100NAS
EX7000-100PAS
Cant seem to find any information that says whats different between the 3.
Also if this would be a good model for setting up as a range extender and then down the road as a access point. I will be wanting to plug in a hard drive to this unit to use as a network storage device to access files between computers, phones, tablets, and TVs. As well as hooking up 3 printers. If you have any other suggestions please do say.
Thank you in advance.
1 Reply
- DarrenMSr. NETGEAR Moderator
Hello Fr0Sty
They are the exact same the number at the end is just the region sku.
DarrenM
