× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Netgear Extender WN2500RPv2 (46V1527TA0190) can't sent signal via ethernet
Karlev
I have Netgear Extender WN2500RPv2 that does not send signal to 2 devices that are connected via ethernet. One cable goes to a switch
that is connected to 2 PCs and the other cable goes to Netgear Arlo system. None of the connected devices get signal.
I have tried all the troubleshooting suggestions, but unsuccessfully. Can anyone help, or is the extender defective?
Model: WN2000RPTv2|Universal WiFi Range Extender
Message 1 of 3
DarrenM
Sr. NETGEAR Moderator
Re: Netgear Extender WN2500RPv2 (46V1527TA0190) can't sent signal via ethernet
Hello Karlev
If the unit is still under warranty I would suggest contacting support.
http://www.netgear.com/support/contact.aspx
DarrenM
Message 2 of 3
Karlev
The unit was still under waranty, so I have replaced it with a new.
Message 3 of 3
Discussion stats
  • 2 replies
  • 2247 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
