× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
Netgear Extender WN3000RPv2 (Can not get valid IP)
markshores
Follower
After doing a factory reset of the extender the device will no longer give a valid IP thus not able to login to dashboard.  I tried multiple times same results.  Is there a workaround for this or if the extender pretty much a brick?
Model: WN3000RPv2|N300 WIFI Range Extender
Message 1 of 2
Guru
Re: Netgear Extender WN3000RPv2 (Can not get valid IP)
how are you connecting to it?
hardwired? wireless?
Have you tried hardwiring into it and running through the setup?
Have you tried installing it using wps? I usually don't recommend that method but sometimes it works great.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 302 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
