Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Netgear N300. No internet. Sign in. "Reset""1"
- Mark as New
- Bookmark
- Subscribe
- Permalink
2021-07-10
12:24 PM
2021-07-10
12:24 PM
When I try to connect to internet, sends me to mywifiext site to sign in.
Says : "reset" "1"
Seen other posts with same problem and no solution.😡
Says : "reset" "1"
Model: EX2700|N300 WiFi Range Extender Essentials Edition
Message 1 of 2
- Mark as New
- Bookmark
- Subscribe
- Permalink
2021-07-11
06:48 AM
2021-07-11
06:48 AM
Re: Netgear N300. No internet. Sign in. "Reset""1"
1. why are you connecting to the guest network? (in your photo)
2. what router did you connect it to?
3. did you setup the extender using wps or using the installation assistant?
If you used wps, I'd highly recommend factory resetting the extender and installing it using the installation assistant
Message 2 of 2
Announcements
