×  Introducing Nighthawk RS700 WiFi 7 (BE) Router. For more details, please visit Nighthawk Tri-Band WiFi 7 Router.
Reply
Netgear NightHawk 6000 - Slow loading when resetting my computer
Hammer955
I installed the NightHawk 6 about one year ago and whenever I reset my computer, the last thing to load is the Netgear product and it takes sometimes 5-8 minutes to complete the process of loading fully on my computer. Is this normal? Is there a fix?
Model: EX6000|AC750 Dual Band WiFi Range Extender
Message 1 of 6
jvasanth1984
Virtuoso
Re: Netgear NightHawk 6000 - Slow loading when resetting my computer
Hi @Hammer955,
                             Do you mean to say that when you turn on EX6000, it takes 5-8 minutes to turn on and get ready?
Message 2 of 6
Hammer955
No! I leave the Netgear on and running continuously! The problem is that when i reset my computer(iMac), the programs that i have on my Mac load first which takes a couple minutes and then the Netgear loads last and it is the 5-8 minutes during the Netgear loading process...very slow!
Message 3 of 6
jvasanth1984
Virtuoso
Hi @Hammer955,
                             Could you please explain in detail about what you refer to "Netgear loads"?
Message 4 of 6
Hammer955
When I reset my computer or turn it off and turn it back on then all my programs reload back onto the computer screen.
Message 5 of 6
jvasanth1984
Virtuoso
Hi @Hammer955,
                             So, do you have a Netgear application on your PC like Genie which takes time to load?
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 1141 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
