×  Introducing Nighthawk RS700 WiFi 7 (BE) Router. For more details, please visit Nighthawk Tri-Band WiFi 7 Router.
Reply
Netgear Nighthawk satellites aren't detected
eb2114
Tutor
I have a Nighthawk mesh system (1 router, 2 satellites) that's been in place for about two years. Two-three weeks ago, I notice that the light on the satellites had turned red/amber and they were showing up as "offline" in the app even though devices were still contected to them.
Today, the satellites wouldn't even show up in the app.
I did a factory reset on all the devices and went through the home network set up again and I'm getting nada. The satellites can't be detected in the app and aren't connecting to the router.
Router firmware is v. 1.0.6.116
No idea what the firmware is for the satellites as I can't access them at all. Anyone have advice on how to get the damn things to even show up in the app?
Thanks
Message 1 of 4
Accepted Solutions
Guru
Re: Netgear Nighthawk satellites aren't detected
Bring the satellites to the router and hardwire them in.
hardwire them and give them a few minutes.
then log into the router through the browser and you should be able to see the satellites and their firmware.
Make sure they're on the same firmware as the router.
Current setup: CM2000-> RBKE963B-> Trendnet TEG-S380-> GS716T-> pi-hole
also in AP setup: RAXE500->EAX80
1.4gig download/50mbps upload from Xfinity
We’re members of the public helping out on our own time.
Message 2 of 4
All Replies
Guru
Message 2 of 4
eb2114
Tutor
That worked great. Thanks!
Message 3 of 4
Guru
glad it worked!
If you mark it solved, it might help the next person with that issue
Message 4 of 4
Discussion stats
  • 3 replies
  • 1195 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 6E
