Kennyb8's avatar
Kennyb8
Follower
Jan 31, 2024
Netgear eax20 ax1800 mesh extender
My range extensible not show up after I plug it in. My phone will not recognize it
1 Reply
  • plemans's avatar
    did you set it up using wps?
    If so, that's how it should work as its a "MESH" extender. Meaning it uses the same ssid as the router and lets devices roam seamless between it and the router.
