Drinkinmycup's avatar
Drinkinmycup
Follower
Jan 24, 2021
Netgear range extender keeps disconnecting
i login to my range extender and it keeps dropping ocnnection and i have to keep restarting it (powercycling)
1 Reply
  • plemans's avatar
    We'd need more info that what you've given us to help you.
    It only happens if you're logged into the extender?
    What firmware is on the extender?
    What router is it connected to?
    How far from the router is it?
    What wall type/materials are between the router/extender?
    How frequently does it happen?
    Is it both 2.4ghz and 5ghz that drops?
    Have you tried changing wireless channels?
