Mattharp73's avatar
Mattharp73
Follower
Dec 07, 2017
Network extender
Was wondering if there is a extender that you can plug in a Ethernet cable and then it puts out a wifi signal. Cause the room I'm trying to get wifi threw doesn't get good signal the wifi now has to go there concrete walls so I figure if I put signal in the room it will work much better.
1 Reply
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Yes most of our extenders that have a ethernet port can be used as a AP.
    DarrenM
