- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
New AC1200 Dual Band WiFi Mesh Extender - Slow Connection
- Mark as New
- Bookmark
- Subscribe
- Permalink
As a side note, when I use the Nighthawk mobile app there is an “update” icon in orange but it doesn’t actually allow me to update, as when I click on it it just takes me to the network map.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
The 5ghz will have faster speeds.
I highly doubt your primary router was hitting 300mbps over 2.4ghz.
Again, 5ghz is capable of faster speeds but not 2.4ghz.
If you don't like the mesh features, you can disable it and just use separate ssids for it.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: New AC1200 Dual Band WiFi Mesh Extender - Slow Connection
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
The EX6150 is a mesh extender. Those speeds are pretty accurate for the 2.4ghz side but not the 5ghz size.
Just for educational, extenders aren't going to increase your speeds, they're going to cover dead spots. Reason they don't increase speeds is because they have a 50% speed drop off. This happens because they have to go router---extender and then extender----devices with the same wireless chip. And it can't do both at once. So thats why it takes at least of 50% speed decrease. Plus you have to account for the extender being a ways away from the router, obstructions, and other wireless interference.
So if you were hitting 300mbps in the same spot as the extender prior, devices connected to it can expect at best 150mbps. But that'd be over the 5ghz. Its a much faster network than 2.4ghz.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I guess my confusion stems from the fact that not only am I not able to figure out how to choose between the 2.4 and 5ghz, I’m now seeing all devices all over the house running on the same network at those slower speeds. In other words, I’m not seeing a way to differentiate between my existing network (pre-extender) and the current network (with extender and slower speeds).
At this point I feel like I sacrificed the speed of my entire WiFi network to combat this one “dead” zone. Is there anything I can mess around with to address this or is my only other option to get rid of the extender completely.
Thank you again!
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Glad it worked for you!
If you took care if it, you can mark it solved so others aren't still trying to fix it 🙂
