- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
New EX7300 can’t connect
- Mark as New
- Bookmark
- Subscribe
- Permalink
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
1. what router are you connecting it to?
2. what firmware is on the extender?
3. what method of setup are you using? WPS or the installation assistant?
Here's the assistant: How to Setup your WiFi Range Extender with NETGEAR Installation Assistant - YouTube
If you tried setting it up using wps, try factory resetting. push and hold reset for 7-15 seconds while powered on.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
