Reply
New wifi network
aarnold9o
Follower
New wifi network
I Successfully connected my netgear range extender to my networkmin the past following the quick start directions.  But now I want to connect to a new network.  How do I zero out the existing information to start again.
Specifically, I do not get the NETGEAR _EXT network as stated in the directions.
Thanks for any help you can provide.
Message 1 of 2
Guru
Re: New wifi network
You can factory reset the extender.
Push and hold reset for 7-15 seconds while the device is powered on.
that should clear out everything and get you back to the defaults.
CM2000-> RAXE500-> GS716v2-> WAX218-> EX8000
Message 2 of 2
Discussion stats
  • 1 reply
  • 22 views
  • 0 kudos
  • 2 in conversation
Announcements
