Reply
Nighthawk AC1900 Problem
Kohbrat
Hello, installed this extender and it works good except for my TV and laptop (PC).
I manually wrote in the IP and DNS when connected to the tv and now it works.
However on my PC there is no access to internet. Connected to the device but no internet.
Message 1 of 4
Guru
Re: Nighthawk AC1900 Problem
Do you have the EX7000 extender?  If so, what firmware are you running?
Message 2 of 4
Kohbrat
Firmware V1.0.1.78_1.0.140
Is this model a "trouble model"?
"Your firmware is up to date" when using www.MyWifiExt.com
Model: EX7000|AC1900 WiFi Range Extender
Message 3 of 4
Guru
No, but there are lots of folks here having trouble with the 1.0.1.78 firmware release.  Try downgrading to 1.0.0.66.  https://kb.netgear.com/000059563/EX7000-Firmware-Version-1-0-0-66
After that completes, I suggest doing a reset on the extender and setting it up again.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 410 views
  • 0 kudos
  • 2 in conversation
Announcements
