×  Introducing Nighthawk RS700 WiFi 7 (BE) Router. For more details, please visit Nighthawk Tri-Band WiFi 7 Router.
Reply
Nighthawk EX8000 X6S - Which app do I use to install?
djmercury73
Follower
I have the Netgear Nighthawk app on ios and while trying to install I get "Extender Not Supported" message.  It also says "The Nighthawk app does not support your extender model."
How am I supposed to install if the app doesn't work?
Message 1 of 2
Guru
Re: Nighthawk EX8000 X6S - Which app do I use to install?
If so, factory reset the extender  and set it up using the installation assistant.
To factory reset, push and hold the reset button for 7-15 seconds while powered on.
Here's a video of how to use the assistant.
https://www.youtube.com/watch?v=yJVklshxBMk
Current setup: CM2000-> RBKE963B-> Trendnet TEG-S380-> GS716T-> pi-hole
also in AP setup: RAXE500->EAX80
1.4gig download/50mbps upload from Xfinity
We’re members of the public helping out on our own time.
Message 2 of 2
Discussion stats
  • 1 reply
  • 158 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
