- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Nighthawk Mesh Extender
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'm unable to setup my extender because it asks for NETGEAR_EXT and there is no wifi connection with that name. Can someone help?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Nighthawk Mesh Extender
There's a support site with access to manuals, firmware, install guides, etc.
Go to https://www.netgear.com/support/
Type in your model number and from there it'll take you to the above.
Its a great resource to start with.
What actual extender do you have?
did you hit the wps button? if so, it could be already setup using the same ssid as the router. That's part of it being a mesh extender.
If so, you could try factory resetting it by pushing and holding reset for 7-15 seconds while powered on.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks! I will try a reset and start over.
