× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Nighthawk RAX120 AX12 wifi6 outdoor extender
bisweet
Follower
Looking for an outdoor extender (without POE) that is compatible with my RAX120 Nighthawk AX12 router. Something similar to Orbi Outdoor satellite WiFi extender (RBS50Y) would be great but I heard this is not compatible with wifi6.  There is no cat5 cabling available in the area that I need to install it.  Any suggestions?
Model: RAX120|Nighthawk AX12 12-Stream WiFi Router
Message 1 of 4
Guru
Re: Nighthawk RAX120 AX12 wifi6 outdoor extender
I don't know of any current netgear extenders that are AX and outdoor rated.
I've seen people use outdoor rated enclosures and putting extenders in them. The only caution is this is making sure they don't overheat.
Message 2 of 4
Guru
that are consumer grade anyway.
Message 3 of 4
pkgadd
Apprentice
...and avoiding condensation.
Message 4 of 4
Discussion stats
  • 3 replies
  • 490 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
