×  Introducing Nighthawk RS700 WiFi 7 (BE) Router. For more details, please visit Nighthawk Tri-Band WiFi 7 Router.
Reply
Nighthawk X6S EX8000 - Firmware interrupted, unit bricked
Retired_Member
Not applicable
Nighthawk X6S, AC3000 Tri-Band WiFi Extender, EX8000: Firmware update was interrupted.  Unit was bricked.  Red flashing power light, all white LEDs flashing.  Did a factory reset: constant hold, 30 seconds w/ power on / 30 seconds turning power off / 30 seconds power on.  Now, red flashing power light, no LEDs.  I do not have a Windows device.  Any suggestions?
Message 1 of 2
Guru
Re: Nighthawk X6S EX8000 - Firmware interrupted, unit bricked
You can try recovering it with tftp or nmrpflash.
You might want to try borrowing a windows device. Otherwise you can search the forum for mac os guides.
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through using a tftp client. Use the built in one for windows 10 though. the video is more of an example of how its done.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
https://github.com/jclehner/nmrpflash
Current setup: CM2000-> RBKE963B-> Trendnet TEG-S380-> GS716T-> pi-hole
also in AP setup: RAXE500->EAX80
1.4gig download/50mbps upload from Xfinity
We’re members of the public helping out on our own time.
Message 2 of 2
Discussion stats
  • 1 reply
  • 208 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
