- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Nighthawk X6S EX8000 Issues
- Mark as New
- Bookmark
- Subscribe
- Permalink
EX8000 - firmware updated, unit drops the connection without continuous use, if I turn off the extender, the connection from router works fine.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
After over an hour with tech support, it was concluded the unit is defective.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Nighthawk X6S EX8000 Issues
Hi @JayLo,
Welcome to the community!
1. It is recommended that a factory reset is done after a firmware update.
2. Does the issue persist on both bands (2.4GHz and 5GHz)?
3. Does the issue persist on all your wireless devices?
4. Have you tried changing the wireless channel of the main wireless network?
5. When it drops, does the extender still broadcast the wireless network?
Dexter
Community Team
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have reported a similar issue like the one you experienced and just came across your post. Do you have a number I can call tech support?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Work amazing for 2 weeks then started to reboot every hour or so.
Tech support in India just told me to replace where I purchased . So I swapped it over for a new R8000 fingers crossed.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'm having same issue and here are the answer to you question; I also opened a case with Netgear and its been 7 days since I received last email and haven't heard anything.
1. It is recommended that a factory reset is done after a firmware update. Done
2. Does the issue persist on both bands (2.4GHz and 5GHz)? Yes
3. Does the issue persist on all your wireless devices? Yes
4. Have you tried changing the wireless channel of the main wireless network? Yes
5. When it drops, does the extender still broadcast the wireless network? Yes, clients connect to extender but no Internet, some clients that always stay on don't ave the issue but if they get restarted, they connect but don't have access to Internet.
User | Count |
2 | |
1 | |
1 | |
1 | |
1 |
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
