- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Nighthawk app no longer works with my EX7700 X6 wifi extender
- Mark as New
- Bookmark
- Subscribe
- Permalink
Every so often the EX7700 X6 wifi extender just seems to slow down and sometimes I find the Nighthawk App on my iphone no longer works. Recently I factory reset and tried several times to get the app to work again but alas it doesn't. I can get to it via the browser but there is little to see there in way of connected devices and speed testing.
Anyone else had this issue? Any ideas on how to get the Nighthawk iPhone app working again?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Nighthawk app no longer works with my EX7700 X6 wifi extender
Be sure to disable WiFi Private IP address and IP Address Tracking for the wifi network your connecting too. See if this helps.
- Mark as New
- Bookmark
- Subscribe
- Permalink
ty but it was working and nothing else has changed on my wifi network.
- Mark as New
- Bookmark
- Subscribe
- Permalink
What router are you connecting it to?
did you set it up using wps or the installation assistant?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Connected to my ISP router, has it has been for a couple of years now. Every so often I have needed to factory reset or reboot because of slowness but this is the first time the nighthawk app won't re-discover the extender.
- Mark as New
- Bookmark
- Subscribe
- Permalink
This also has recently started happening to me. The web app config works fine. I'm using the EX6410. It's connected to the router, but has no internet access.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi @David9 and @reubster,
Thank you f reaching out. We are sorry for not being able to get back to you immediately. May we know when exactly did you notice the issue on your extenders? Also, did you do a firmware update recently? If yes, have you tried using a different firmware version?
https://kb.netgear.com/000061572/How-do-I-manually-update-the-firmware-on-my-NETGEAR-WiFi-Extender
Please do not hesitate to let me know if you need further assistance.
Oliver
Community Team
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you for following up.
I hadn't used the app in a while. I don't use it all the time but generally did just to check the performance, which you cannot do through the web portal, typically when it appears to be slowing down and requires a reboot. I have not been able to get the app working in some time.
The firmware version is
- Hardware Version: EX7700
- Firmware Version: V1.0.0.226
I understand that this is the latest according to the update page.
- Mark as New
- Bookmark
- Subscribe
- Permalink
> After changing from my ISP and putting in a new router. I solved the problem with connectivity for myself recently - I found that my router was assigning the extender an ip of 192.168.1.250. When I removed the assignment and set it to use .254 then it's worked fine.
I still can't get the Nighthawk app to work though. I've deleted it completely and reinstalled.. it still won't find my extender. I get stuck in a loop where it wants me to reset the extender.. so it can join the temporary wifi.
The web app works fine.
> I don't know. It's the app not the extender.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Our support team is looking into this issue and would like to work with you
I would like to endorse you to NETGEAR Level 2 support team for a callback. Please provide the following information:
Name:
Email:
Phone:
Preferred schedule (at least 2 days ahead)
Timezone:
Device S/N:
Alternatively, if you wish to be contacted via email only then kindly include your preferred email address.
I am looking forward to your response.
Oliver
Community Team
- Mark as New
- Bookmark
- Subscribe
- Permalink
Oliver, I'd rather not post my personal details here. Can you provide an email address that I can use?
- Mark as New
- Bookmark
- Subscribe
- Permalink
@David9 Send it to @olympos1625 in a private message/direct message. Click on their profile and from there click on "send this user a private message"
