Mel70's avatar
Mel70
Nighthawk app states that EX6250 extender not set up but is connected and working
At one point our extender needed to be reconnected to our router.  I followed the steps on my computer and extender is connected and working properly.  The Nighthawk app states the extender is not set up and wants to go thru the setup steps but the extender does not need to be set up.  When I got thru the steps in the app it gets to the connecting to extender step and says the extender is not found and need to connect to NETGEAR_EXT.  NETGEAR_EXT does not show in my wifi setting to connect because the extender is already connected to the router. Is there a way to get the app fixed to it recognizes that the extender is connected and working properly?  I have uninstalled and reinstalled the app, restarted the wifi and extender routers everything connects and works properly but the app still won't recognize that the extender is connected.
  • plemans's avatar
    are you able to manage it through the browser?
    If so, I wouldn't worry to much about the app.
    • Mel70's avatar
      Mel70
      I have only used the browser for setting up.
      I have only used the app for managing.
      How do you manage thru the browser?
      • plemans's avatar
        You can log in through mywifiext . net
        or using the extenders IP address. (found in the routers attached devices list)
