× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Nighthawk extender nessuna connessione con iPad e iPhone
PaoloDaleffe
Il mio iPhone 12 e l'iPad mi danno l'avviso di 'nessuna connessione' quando mi collego con le reti 2.4G e 5G dell'extender.
Il mio PC Windows invece si connette senza problemi.
Ho già fatto più volte il reset e poi riconfigurato l'extender ma niente da fare.
Il firmware è aggiornato.
Il router è un Alcatel HH71.
Qualcuno mi può aiutare?
Paolo
Message 1 of 9
Accepted Solutions
PaoloDaleffe
Re: Nighthawk extender nessuna connessione con iPad e iPhone
Nighthawk extender is now connected with a Technicolor router and it works smoothly.
Don't know why but the probem was surely with Alcatel router.
Many thanks
Message 9 of 9
All Replies
Guru
when you're installing, do you use the installation assistant or install using the push-button WPS method?
Message 2 of 9
PaoloDaleffe
I tried both ways.
Message 3 of 9
Guru
I haven't seen anyone post about using an extender with that router.
have you tried setting up the extender with a static ip address in the Alcatel HH71
Message 4 of 9
PaoloDaleffe
I tried with a static IP addrees in the Alcatel but it doesn't work.
For your information when my iPhone and iPad are in 'no connection' status the following IP address is shown:
IP Address: 169.254.7.52
Subnet mask: 255.255.0.0
Router gateway: none
While the correct IP address from the Alcatel router should be:
IP Address: 192.168.1.10(X)
Subnet mask: 255.255.255.0
Router gateway: 192.168.1.1
Message 5 of 9
Guru
What extender is it and what firmware is on it?
Message 6 of 9
PaoloDaleffe
Extender EX7700 Nighthawk X6 Triband.
Firmware downgraded to 1.0.0.206 from 1.0.0.216: both with the same problem.
Model: EX7700|AC2200 Nighthawk X6 Tri-Band WiFi Mesh Extender
Message 7 of 9
Guru
have you checked with alcatel? it seems like that router only supports 32 devices which isn't a standard amount. most support quite a bit more. Not sure if they have something limiting it
Message 8 of 9
PaoloDaleffe
Many thanks
Message 9 of 9
Discussion stats
  • 8 replies
  • 1156 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
