- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Nighthawk mobile app "Enter Password to Verify" issue
- Mark as New
- Bookmark
- Subscribe
- Permalink
Im trying to connect to a range extender using my iPhone and when I get to the screen where you enter the password for your wifi network, the phone's keyboard comes up and will not go away, so I can't press the button that says "next". There is nothing I can tap on the screen to put the keyboard away, switching to and from other apps doesn't work, and even if I shake my phone to prompt the "Need help" screen, once you cancel out the keyboard comes back up after a second and hitting "next" during that window doesn't register.
Im moving houses and I've used this device before so I know I've been past this screen and can't believe I'm unable to figure this stupid problem out.
I find it hard to believe I'm the only person this is happening to, but I can't find any similar posts on this forum.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Nighthawk mobile app "Enter Password to Verify" issue
have you tried setting it up using the installation assistant in the browser and not the app?
How to Setup your WiFi Range Extender with NETGEAR Installation Assistant - YouTube
User | Count |
2 | |
1 | |
1 | |
1 | |
1 |
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
