Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Nighthawk x4S EX7500 booting forever
- Mark as New
- Bookmark
- Subscribe
- Permalink
2019-03-27
03:58 PM
2019-03-27
03:58 PM
I purchased brand new expensive repeater. Plug it in the power outlet set it up. I used it for one week. Came home after I plugged it in the socket its booting forever. Blue light blinking. I tried to turnit it off. Without success. I wanted to restart. Reboot nothing. I keep pressed rebot button for 5 seconds 30 seconds, 1 minute nothing. Its stil power led blinking and blinking. I can not believe that I paid a fortune for the device that is stable for a week. What can I do mext?
Model: R7800|Nighthawk X4S AC2600 Wifi Router
Message 1 of 2
- Mark as New
- Bookmark
- Subscribe
- Permalink
2019-03-27
06:16 PM
2019-03-27
06:16 PM
Re: Nighthawk x4S EX7500 booting forever
Blinking blue on the power light means its resetting to default settings. You might have interupted that by turning it off. You stated " wanted to restart. Reboot nothing. I keep pressed rebot button for 5 seconds 30 seconds, 1 minute nothing. Its stil power led blinking and blinking"
I'm not positive you were using a pin to hold in the factory reset button on the side. Use a pin to hold that button in for around 5-10 seconds. It should factory reset the device. Let it boot for a couple minutes. See if that resolves it.
Message 2 of 2
Announcements
