× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Nighthawk M6 Pro Unlocked Hotspot 5G mmWave
Reply
Nighthwak M1
TIJ
Follower
Follower
Nighthwak M1
I was told I should buy a Nighthawk M1 to add to my AT&T mobile hot spot in my home so I could add more connections for WiFi.  Will the Nighthawk do that?  Does it just connect to my hotpsot to do that or does it replace my hotspot?
Model: MR1100|Nighthawk M1 Mobile Router
Message 1 of 2
JohnPeng
NETGEAR Expert
Re: Nighthwak M1
What is your AT&T mobile hotspot you are using?
Thanks
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 852 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
