- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Not getting 300mbps on Ex2700
- Mark as New
- Bookmark
- Subscribe
- Permalink
I expected to get upto 300mbps on my EX2700 and I am only getting 10mbps, I can't game with it. My virgin media router gives me 200mpbs, but it doesn't go to my room so I bought the EX2700 and I saw that it will give me upto 300mbps but I did an internet speed test and run games with it and the results are bad and I only get 10mbps. Any help, I would appreciate.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Not getting 300mbps on Ex2700
While connected to the extender wireless, point a Web browser to http://mywifiext.net, login to the EX2700, and post the Status page.
This is a very similar EX3700 (but with two radios) - shwoing only the 2.4 GHz here:
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Your EX2700 seems to have a good link to the primary router, but it does run this link on 144 Mb/s link rate only. This does also limit the maximum possible link rate of the EX2700 access point which does run on the same radio and therefore the same channel like the primary router.
First item to check is if the Virgin media router 2.4 GHz wireless can be reconfigured to 40 MHz (20+20 MHz) bandwidth, this should allow the EX2700 operate the link to the primary router on about 270...300 Mb/s, and it will serve the EX2700 access point on up to 300 Mb/s, too.
Next check the signal level (quality) on the computer or gaming device. Relocating the EX2700 a little bit more towards your room might help.
Please be aware that the physical link rates can't be reached in the effective throughput. However, in your case the 144 Mb/s (assuming the computer or gaming device should sync to about the same number) only 10 Mb/s throughput not ideal. In a similar application, the EX3700 (similar tech on 2.4 GHz as the EX2700) does run in the 15 .. 35 Mb/s range. Here however we have massive traffic on air in the 2.4 GHz band from two Arlo systems, so (massive) interferences are predictable.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I've tried the methods but I only got at least 15 mbps, ;(
- Mark as New
- Bookmark
- Subscribe
- Permalink
I just need at least 50 - 75 mpbs
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
So what should I do, I have very angry and upset that it doesn't go more than at least 80
- Mark as New
- Bookmark
- Subscribe
- Permalink
Auric,
Please send me a message with your contact info and serial number. I'd like to get our support team to reach out to you.
Christian
- Mark as New
- Bookmark
- Subscribe
- Permalink
Oh yeah about that, I already sent the item back and I am getting refunded. Didn't expect such low mbps from a product that could give me upto 300mbps. I am getting a tp link powerline instead.
