× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
One more WIFI extender to WN2000RPTv3
kjellj
Follower
I need another WIFI extender to be used downstairs. Upstairs I already use WN2000RPTv3, which I believe is not sold any more in Sweden.
Is there a problem using two extenders and which model should I buy to work with the existing one ?
Message 1 of 2
Guru
Re: One more WIFI extender to WN2000RPTv3
Normally extenders connect to your router, not to each other.  What router do you have (manufacturer/model)?
BTW, one thing to consider is whether you'd be better off in the long run getting a WiFi mesh system like Orbi.  That would be more expensive up front, but would give you much better wifi speeds than you can get with a WN2000RPTv3.
Message 2 of 2
Discussion stats
  • 1 reply
  • 395 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
