iwheaton's avatar
iwheaton
Outside Coverage
Hi, I have an AX8 and it is in my office inside my house.  How do I boost the signal to reach outside on my patio at the back.  Previously I had an Apple Airport Express working with an Apple Time machine and it just plugged and played.
Can I just plug that in?  Do I need something else from Netgear?
Thanks,
  • plemans's avatar
    You have a hardwired connection ran out there?
    If so, you could use a range extender or router in AP mode. Or you could just use a range extender in extender mode.
    • iwheaton's avatar
      iwheaton
      Thanks, I am picking up an AC1900 range extender this morning.  Hopefully that does the job.
