ggerstner's avatar
ggerstner
Follower
Apr 15, 2019
PLP2000 Distance/connection limitations
Good Afternoon
I am considering a PLP2000 for our property, and have a question about distance limitations
We have two houses, the main and a guest house
Each house has it's own power service pulled to it.
The power lines from the transformer to each house run about 300 feet going house to transformer to house.
Will this product work in this environment?
1 Reply
  • plemans's avatar
    Theoretically? maybe.
    In practice? I'm betting no.
    Reason is this. Powerline tends to be sensitive to any type of influence. Even arc fault/gfci circuit tend to degrade or make connections degrade. Going from an in house circuit--->mains power-->in house circuit is going to have quite a bit of interference. Add in the problem of distance (max distance is usually 200-300 meters) and even if you did get a signal, I'm doubting it'd be usable.
    I've never tried it so I can only go off my experience in dealing with powerline.
