- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Password not pulling through
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi
I have a AC1200 Dual-band wi-fi range extender.
I think it has been setup correctly as I can see the 2 extended bands on my wireless network.
It was set up using the WPS buttons on the router and the extender.
However I cannot get the extended bands to recognise the password to my wireless network.
I have tried on Iphone, Macbook and Windows PC.
Every time I try I eventually just get the 'Cannot join network' message.
It would be great if someone could tell me what to try next.
Thank you.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Password not pulling through
Hi - I just had this exact problem....I finally solved it today by first resetting the extender to factory and then restarting my router. I then reconnected the extender to the router via WPS.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Sorry - should have added that the password attached to the extender was completely different to my router....needed to access the netgear genie (from my pc) to reset the extender password. Once I did that I had no probles joining my mobile devices to the extender.
- Mark as New
- Bookmark
- Subscribe
- Permalink
please can someone help.
i am having the same issues. i have 3 solid green lights. power WPS androuter link
i then try to connect one of the following 2GEXT or 5GEXT and i enter my router password. it then tells me that the password in incorrect.
please help
- Mark as New
- Bookmark
- Subscribe
- Permalink
Try resetting the extender and don't press WPS. You'll then see the NETGEAR_EXT network. Join that, and browse to www.mywifiext.net. From there you can complete the setup (w/o needing WPS).
